glashoppah
Sep 30, 2015Aspirant
Failed drive replaced in Pro Business, can't tell what's up.
I've had my Pro Business for years now. I've moved from 6x500G to 6x1T to 6x2T over the years, and have always used Seagate Constellation ES.2 drives. I have a drive failure about once every 18 mon...
- Oct 02, 2015
You'd need to download them.
system.log, kernel.log, expansion.log, user.log are probably all places to look.
vandermerwe
Sep 30, 2015Master
Do you have a backup? Replacing a failed disk and the resultant resync can expose other problematic disks, you don't want to end up with a dual disk failure with single redundancy. Are you using single or dual redundancy?
Did you test the disk before you put it in?
The volume tab should tell you if a resync is taking place or not, does it? It should not take more than about 12 hours with 2 tb disks.
A reboot is usually advised if there no evidence of the rebuild starting, but I would advise you to make sure you have a backup first.
Sep 30, 2015Guru - Experienced User
Usually hovering the mouse over the drive or volume icons gives you an indication of progress. What firmware are you running?
There are drive failures that can disrupt the SATA interface, and cause the driver to shut it down. Though I'd have expected that to block detection of the new drive insertion.
I suggest rebooting (maybe shutting down, removing power for a bit, then restart).
If the resync doesn't start I would remove the drive and reinsert it (NAS running).
- glashoppahOct 01, 2015Aspirant
Here is the volume display:
and the "Health" display:
I'm running v4.2.27 of RAIDiator.
What's puzzled me is that, since the original log message saying the drive would be used to rebuild the array, there have been zero log messages concerning status of the drive or array.
H. - glashoppahOct 01, 2015Aspirant
Another interesting data point - from the RAIDar app, which appears to think the third drive is good:
H.
OK - I threw caution to the wind and rebooted. Not like it could get any worse. And now that it's restarted, the rebuild has commenced (RAIDar display below after reboot). So now my question becomes - why didn't it rebuild after the hot swap?
H.
- StephenBOct 01, 2015Guru - Experienced User
glashoppah wrote:
...So now my question becomes - why didn't it rebuild after the hot swap?...
Hard to say, perhaps the logs would provide some clues.
If the rebuild completes ok, I'd just leave it as a tech mystery though.
