timnas
Jan 20, 2017Aspirant
File system broken after power cut down
Recently, there were electrical works in my building and appartment that caused a power cut down.
The beep of my UPS was probably to annoying for workers so they decided to unplug the NAS that was then running on the battery (facepalm).
When power was restored, I plugged it back on my UPS, and press the start button. Then I received an email:
New disk detected. [Disk 1] (Nas) A new disk was added to the ReadyNAS. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time.
Wow! No! It's not a new disk! Wait...
And guess what? ... Power cut again, and unplugged from battery again.
Since then, it won't start. So I extracted the disk, tried to clean, to put it back several times, then I decided to proceed to a check/repair/forensic journey...
When I analyze the partition structure of the 2 TB disk, it seems to be partially broken. I use a Freecom Hard Drive Dock Duplicator to both connect the disk to USB to a working machine (and old 32-bits IBM X60) and duplicate the disk autonomously as is to be sure I have a backup if I did something wrong. What I want to achieve is either:
- fix the booting issue and make the NAS start as usual
- or retreive all the data from the disk and start a fresh install of the NAS, loosing all the configuration I did (scripts and crons and manually installed services and security tools etc.).
When docked through USB, the device is mounted as /dev/sdb, /dev/sdb1, /dev/sdb2 and /dev/sdb3.
Please note that I'm not familiar with RAID, filesystems, disk partitionning and data forensics.
The following is all I have, without being sure of what it means. Please tell me if you see/understand something in this mess, and if I'm wrong.
sudo mdadm -E /dev/sdb3
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x1
Array UUID : 1858b355:7c24531e:2fddde7f:10cf1e0b
Name : x60:99 (local to host x60)
Creation Time : Sun Jan 1 19:35:50 2017
Raid Level : raid1
Raid Devices : 1
Avail Dev Size : 3897323368 (1858.39 GiB 1995.43 GB)
Array Size : 1948661632 (1858.39 GiB 1995.43 GB)
Used Dev Size : 3897323264 (1858.39 GiB 1995.43 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
Unused Space : before=262056 sectors, after=104 sectors
State : active
Device UUID : a8fe3d88:cb0c2668:fe0eac8d:b3b5d84c
Internal Bitmap : 8 sectors from superblock
Update Time : Sun Jan 1 19:35:50 2017
Bad Block Log : 512 entries available at offset 72 sectors
Checksum : 2ebf2efb - correct
Events : 0
Device Role : Active device 0
Array State : A ('A' == active, '.' == missing, 'R' == replacing)
testdisk
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63
Partition Start End Size in sectors
P Linux Raid 64 8386607 8386544 [E0469AA064B8:0]
P Linux Raid 8388672 9437231 1048560 [E0469AA064B8:1]
>P Linux Raid 9437248 3906760519 3897323272 [E0469AA064B8:2]Since then I did something wrong, before cloning the disk so the mistake is forever:
tried testdisk partition discovery and write partition structure to disk
>P Linux Raid 9437248 3906760519 3897323272 [x60:2](How can I rename the third partition so it is back to original name?)
Assembling the RAID partition
sudo mdadm --assemble -v /dev/md99 /dev/sdb3
sudo mdadm --query --detail /dev/md99
/dev/md99:
Version : 1.2
Raid Level : raid1
Used Dev Size : 1948661632 (1858.39 GiB 1995.43 GB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistent
Intent Bitmap : Internal
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
Events : 0
Number Major Minor RaidDevice State
0 8 19 0 active sync /dev/sdb3
sudo mount -t btrfs -o ro /dev/md99 /mnt/nashd/
mount: wrong fs type, bad option, bad superblock on /dev/md99,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.Any ideas?
Thank you.
Tim
- JennCNETGEAR Employee Retired
Hello timnas,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- timnasAspirant
To be honest, I was expecting more something like
StephenB says: No worries buddy, your data are still there.
Just apt-get foo-barfs and mount a ext4 volume with offest 42.Me : Dude, you're the guru among the gurus.It works like a charm.
Please accept my eternal gratitude. May I pay you with Beercoins?
Anyway, and at last, I was able to retrieve all my data from my 2 TB HDD just today.I am now able to mount every partition:
- System (ext3 - 4GB)
- Restore? (can't remember - 512 MB)
- Data (ext4 - 1.8 TB)
But if I am now technically able to fix the booting issue of the NAS, I don't know what to start with.
I guess a serial console would help debugging the booting process, or a directly-connected display...
In last resort, I will buy a new HDD and proceed to a factory reset :(
Please accept my eternal gratitude. May I pay you with Beercoins?Beercoins? You didn't say that before :smileywink:
Your situation looked delicate, I didn't want to offer advice that might backfire and make it worse. FramerV's suggestion on paid support seemed appropriate to me.
- FramerVNETGEAR Employee Retired
Hi timnas,
I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
- timnasAspirant
FramerV wrote:I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
Thank you for you suggestion.Since it is available only 90 days, support period had ended years ago for me (2012).
I'm not ready to pay for a phone support session, so I'd better go with the factory reset option.
I will know if it is a hardware or a software failure then.
