Scads
Dec 16, 2015Aspirant
FW 6.4.1 Problems: Power Timer not working
Firstly, you need to know that I'm using a RN102, obviously with FW 6.4.1 loaded. Mostly I'm pleased with the changes made so far, but there are two problems which do need to be solved: As so many ...
mdgm-ntgr
Dec 16, 2015NETGEAR Employee Retired
The unit won't scheduled power off while a backup job is in progress. It should power off once the backup completes if when the backup completes the NAS isn't meant to be back on by then.
- ScadsDec 20, 2015Aspirant
Thank you for your reply, but this doesn't appear to happen. If backups or snapshots are scheduled, power off does not occur. The new manual clearly suggests that Power Timer off command should take precedence, but each time this is suspended (even though backups or snapshots are not in progress at the time) and does not happen when the events are completed.
This appears to me to be a firmware fault, and was not evident in versions before 6.4.
Scads
