Rynar401's avatar
Rynar401
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. Further research showed that I had incompatible hard drives in my ReadyNAS. Also I found this information on Western Digital website..
http://community.wdc.com/t5/Desktop/WD15EADS-00P8B0-Really-slow-Or-am-I-just-crazy/td-p/1547
Well I had already spent about $700 for all the hard drives so since the server did kinda work I waited about a year till I was ready to replace them with compatible higher performing hard drives. So now I have 3 2 Terrabyte hard drives and am wondering if I can do a swap from 4 hard drives down to 3 even though the total capacity is the same. I wanted to do it this way so I would have an empty slot for future expansion. If this is possible how should I go about doing it.. Do I
    1. Swap 1 drive at a time until all 3 2tb are in it and then just pull the 4th 1.5tb drive and call it done?
    2. Pull the 4th drive 1st, let the readynas repopulate any info (if thats what its going to do) and then start swaping the three drive 1 at a time.
    OR
    3. No stupid you cant go from 4 drives to 3. What were you thinking? Buy the 4th drive before attempting this, or back everything up and start fresh with the 3 drives.
So I believe these are my options. Please help. My current hardware and settings are as follows.
ReadyNAS NVX Pioneer Edition Server running Frontview 4.2.19 on xRaid2
RAIDar 4.3.4
4 1.5TB Western Digital Caviar Green WD15EADS-00P8B0 currently in it (not on compatibility list) 32mb cache @ 3gb/s
3 2TB Seagate Barracuda Green SG-2000DL003 waiting to go in it (on compatibility list) 64MB cache @ 6Gb/s
I am also running a laptop windows 7 with an i7 processor 8GB of ram gigabit ethernet and wireless N
Netgear WNDR3700 N600 gigabit dual band wireless N router
Oh and a last note, My server is only 38% used if this makes a difference..
  • Thanks for the quick reply. Unfortunately, I tried that and it didn't change anything after reboot. I still have "Disable full data journaling" selected. Do I need to deselect that as well?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    No. Journaling must be enabled (disable journaling unchecked). Setting for full data journaling doesn't matter.
    You will need a fourth 2TB drive installed before the volume will expand
  • Oh. The reason you are only showing 1tb drive is because your #1 slot drive is only 1tb. This will limit all others to that size. Should look into how to configure it so your smaller drive is in slot #4. I believe that will solve your problem. Or just replace it with a 2 tb would be a better choice. Not sure if swapping the order of your drives is a good idea or if it will effect your data.
  • My Ch 1 drive was a 1TB drive. Now there's nothing in Ch 1, and a 2TB drive in channels 2, 3, 4.
    mdgm-ntgr
    Which is one reason why I said you needed a fourth 2TB drive. You cannot reduce the number of disks and get expansion on any ReadyNAS. You'll need to either add a 2TB disk in Ch1 or backup your data and do a factory default (wipes all data, settings, everything).
    If you download your logs (Status > Logs > Download all logs) and extract the zip contents what does your partition.log look like?
  • So they're no way to manually change anything so I don't need to buy another drive?
    Here's my partition log:
    Disk /dev/hdg doesn't contain a valid partition table
    Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
    255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Disk identifier: 0x00000000
    Device Boot Start End Blocks Id System
    /dev/hde1 32 4096031 2048000 83 Linux
    Partition 1 does not end on cylinder boundary.
    /dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
    Partition 2 does not end on cylinder boundary.
    /dev/hde3 4608032 1953092263 974242116 5 Extended
    /dev/hde5 4608040 1953092263 974242112 8e Linux LVM
    Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
    Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
    /dev/hdi1 32 4096031 2048000 83 Linux
    /dev/hdi2 4096032 4608031 256000 82 Linux swap / Solaris
    /dev/hdi3 4608032 1953092263 974242116 5 Extended
    /dev/hdi5 4608040 1953092263 974242112 8e Linux LVM
    Disk /dev/hdc: 999.9 GB, 999991611392 bytes
    255 heads, 63 sectors/track, 121575 cylinders, total 1953108616 sectors
    /dev/hdc1 32 4096031 2048000 83 Linux
    /dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
    /dev/hdc3 4608032 1953092263 974242116 5 Extended
    /dev/hdc5 4608040 1953092263 974242112 8e Linux LVM
    mdgm-ntgr
    That partition log looks fine. You have 4k sector alignment which means you last did a factory default on 4.1.7 or later. Disk 3 /dev/hdg is your parity disk that's why it doesn't have a partition table on it.
    No. You either have to replace the removed disk (considered to be "dead" by the ReadyNAS) with a 2TB disk, or backup and do a factory default (wipes all data, settings, everything).
  • Thanks for the help guys. I guess a new hard drive is in my future!
ProSupport for Business
