Wouter2
Mar 27, 2017Aspirant
How do I mount manually an usb drive on the RN 102
Hello, How do I mount manually an usb drive on the RN102. I have some issues with my usb drive. When connected my usb drive I can only mount the usb drive when I reboot the rn102. I want to mou...
mdgm-ntgr
Mar 27, 2017NETGEAR Employee Retired
Have you checked the health of the USB disk?
Are you safely unmounting it before disconnecting it from the NAS?
Which filesystem is on the USB disk?
Wouter2
Yes , I have already run chkdsk and repair it with windows 10 , the problem is then solved. The usb drive is writable via (touch file) the rn102. When de rsync backup failed the usb disk is not visible anymore in RN102 GUI and again read only. The filesystem of the usb drive is NTFS. I don't want to reboot the rn102 everytime. Í was wondering if it's possible to mount the usb drive via the commandline.
- Wouter2Apr 03, 2017Aspirant
Anyone ???
