dib
Mar 28, 2012Aspirant
Memeo backup premium. Automatic activation - how to
Hello everyone,
I have finally made my Memeo Backup Premium activate itself. I had been searching this forum for answers, found none. I found a lot of people complaining about Netgear support on this topic.
I will not describe the problem and a solution...
1. The not working setup
What is the problem...
When you start Memeo application (usually starts with you system) you can go to the log file. Right-click you Memeo icon in system tray and choose: "Send Log Files". A new e-mail is created in your e-mail client with two attachments, log and xml file. Open the log file. You will see something like this:
"Valid external drive detected = False" :(
So... now we will make it work.
2. The working setup
What is different? The laptop and the ReadyNas are now directly connected with an Ethernet cable.
What you need to setup is
a) enable ETH 1 on ReadyNas (in GUI it is called Ethernet 2)
b) assign an IP to that interface (different that the subnet used on ReadyNas ETH 0)
c) configure a static IP on your laptop (from the same subnet as above). No gateways or DNS needed here.
d) make sure that you can access ReadyNas web page
e) shut down Memeo Backup Premium
f) Connect you laptop to your WiFi network (this is the usual way I use at home)
g) you should be able to access internet now, test it
h) turn off laptop firewall
i) start Memeo Backup Premium
Lets have a look at the log now...
Software is registered :)
We are done!
Conclusions:
1) why some packets are blocked when using the first (not working setup)? I have checked my router logs, but I did not find any information. LAN 1 and LAN 2 should work like a switch, but apparently they don't
2) you will need to connect you laptop directly to ReadyNas, and to your wireless router. The second connection is used to access internet, to be able to register your product.
3) The above may be a problem on PCs with only one Ethernet interface. I assume that getting a simple Ethernet switch (no filters/firewall) should help. I do not have any to check.
Have fun! :wink:
Start Time: 2012-03-28 19:21:24
I: 2012-03-28 19:21:24 (tid BMUMonitorApp) - Searching for: UpnpSearcher
I: 2012-03-28 19:21:40 (tid BMUMonitorApp) - DataString: HTTP/1.1 200 OK
Cache-Control: max-age=1800
ST: upnp:rootdevice
USN: uuid:4d696e69-xxxxxxxxxxxxxxxxxxxxxxxxxxx::upnp:rootdevice
EXT:
Server: Linux/2.6.15-1.2054_FC5 UPnP/1.0 miniupnpd/1.0
I: 2012-03-28 19:21:42 (tid BMUMonitorApp) - DataString: HTTP/1.1 200 OK
CACHE-CONTROL: max-age=1800
DATE: Wed, 28 Mar 2012 17:21:34 GMT
EXT:
SERVER: Unspecified, UPnP/1.0, Unspecified
ST: urn:schemas-wifialliance-org:service:WFAWLANConfig:1
USN: uuid:00000000-0000-1000-0000-xxxxxxxxxxxxb::urn:schemas-wifialliance-org:service:WFAWLANConfig:1
I: 2012-03-28 19:21:42 (tid BMUMonitorApp) - DetectExternalDevice::IsConnected() - NASes found = 0
I: 2012-03-28 19:21:42 (tid BMUMonitorApp) - BMUMonitorShell::ConfigureIfNecessary() - Registered online user = ConsumerKey = xxxxxxxxxxxxxxxxxxxxx, ConsumerSecret = xxxxxxxxxxxx, AccessToken = xxxxxxxxxxxxxxxxxx, AccessTokenSecret = xxxxxxxxxxxxxxxxxxxxx, Username = john.smith, ClientEmail = [email protected]
I: 2012-03-28 19:21:42 (tid BMUMonitorApp) - BMUMonitorShell::RegisterExternalDevice() - Trying to detect external drives
I: 2012-03-28 19:21:42 (tid BMUMonitorApp) - DetectExternalDeviceManager::ExternalDeviceWasDetected() - Valid external drive detected = False
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - DataString: HTTP/1.1 200 OK
ST:upnp:rootdevice
USN:uuid:xxxxxxxxxxxxxxxxxxxxxxxxxxx::upnp:rootdevice
Location:http://192.168.1.5:2869/upnphost/udhisapi.dll?content=uuid:xxxxxxxxxxxxxxxxxxxxxxxxxxx
OPT:"http://schemas.upnp.org/upnp/1/0/"; ns=01
01-NLS:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Cache-Control:max-age=900
Server:Microsoft-Windows-NT/5.1 UPnP/1.0 UPnP-Device-Host/1.0
Ext:
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - Found device at: http://192.168.1.5:2869/upnphost/udhisapi.dll?content=uuid:xxxxxxxxxxxxxxxxxxxxxxxxxxxx
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - Parsed device as: 192.168.1.5:2869
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - DetectExternalDevice::IsConnected() - NASes found = 0
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - BMUMonitorShell::ConfigureIfNecessary() - Registered online user = ConsumerKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxx, ConsumerSecret = xxxxxxxxxxx, AccessToken = xxxxxxxxxxxxxxxxxxxxxxxxxxx, AccessTokenSecret = xxxxxxxxxxxxxxxxxxxxxx, Username = john.smith, ClientEmail = [email protected]
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - BMUMonitorShell::RegisterExternalDevice() - Trying to detect external drives
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - DetectNetGearExternalDevice::HadValidDevice() - NetGear drive connected, product ID = ReadyNAS, vendor ID = NasDevice, serial no =
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - DetectExternalDeviceManager::ExternalDeviceWasDetected() - Valid external drive detected = True
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - BMUMonitorShell::RegisterExternalDevice() - External drives found, trying to auto-register
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - URL = http://register.memeo.info/register3.php
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - date_time = 03-28-2012 xxxxxxx
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - hkey[] = ReadyNAS
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - email = [email protected]
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - p = 0
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - b = 0
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - u = 1
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - buildtype = ng
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - uid = xx:xx:xx:xx:xx:xx
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - lang = en-US
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - eid = xxxxxxxxxxxxxxxxx
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - vers = 4.60.0.7xxx
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - prod = autobackuppro
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - os = Unknown
I: 2012-03-28 20:40:29 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Register variables - prod_level = PREMIUM
I: 2012-03-28 20:40:37 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Server response = <?xml version="1.0" encoding="utf-8"?>
<Registration><Result>Success</Result><ProductKey>MEMNTGR000-xxxxxxxxxxxxxxxxxxxxxx</ProductKey><ValidProduct><PID>ReadyNAS</PID><VID></VID><model_name></model_name></ValidProduct></Registration>
I: 2012-03-28 20:40:37 (tid BMUMonitorApp) - RegisterExternalDevice::RegisterProduct() - Registered. Product key = MEMNTGR000-xxxxxxxxxxxxxxxxxxx
I: 2012-03-28 20:40:39 (tid ) - EngineController::mCheckNetworkTimer_Elapsed() - Getting network paths to find match for disconnected network plans
I: 2012-03-28 20:40:39 (tid ) - EngineController::FindNetworkPathsForPlans() - No network paths found
I: 2012-03-28 20:40:39 (tid ) - EngineController::mCheckNetworkTimer_Elapsed() - Retrying for 1 disconnected network plans
I: 2012-03-28 20:40:40 (tid BMUMonitorApp) - BMUMonitorShell::CreateSubscriptionPlanInfo() - {"stat":"ok"}
I: 2012-03-28 20:40:40 (tid BMUMonitorApp) - TimeBomb::CreateRegistryTimeBomb() - Set expiration date = 03/04/2112 20:40:40, key = ExpirationDatePremium
I: 2012-03-28 20:40:40 (tid BMUMonitorApp) - TimeBomb::CreateRegistryTimeBomb() - Set TimeBomb to expire in 36500 days, key = ExpirationPremium
I: 2012-03-28 20:40:40 (tid BMUMonitorApp) - BMUMonitorShell::DefuseTimeBomb() - Software is registered
We are done!
Conclusions:
Have fun! :wink:
- ubyteAspirantI think I have sucessfully setup the memeo account but do I only get 1GB of data for storage? I thought that it was a lifetime license of the premium service.
uByte - LordRhythmAspirantIf you don't see a notification at the bottom of Memo counting down how many days you have left, you've indeed successfully setup and activated your program.
I never did find out how much online storage you're allotted for Premium Backup, as mine didn't activate successfully, and I can't seem to find out ANYWHERE on their website... I'd definitely shoot an e-mail to Memeo about it, but if they don't advertise it on their website as a certain size, they aren't liable to give you a certain size...
www.memeo.com is their website, [email protected].
I checked their Support database, and there's something that speaks vaguely about a change regarding the unlimited online storage plan, and mentions you can "Purchase Additional Online Storage".
http://support.memeo.com/ics/support/default.asp?deptID=15014 - KorkyAspirantSpent huge amount of time trying to follow dibs recommended steps without success!
Raised a Tech call with Netgear and was surprised when they suggested / pointed me to this same forum link to try out (after I had already spent a few hours trying dibs setup).
As it was Netgear 2nd line support I thought I must be doing something wrong. So I again tried to auto activate the software (spent another 2 days emails back and forth with Netgear) changing my firewall/router settings/IP settings without any luck.
I'm no newbie when it comes to Computer Networks. I was also lucky to have a 02 wireless dongle (3G) and a wireless network adapter. So I had three connections going at the same time. One direct to the Netgear Ultra 6 plus(hard wired) and two wireless connection to the Internet(one using the 02 3G network and the other a netgear WG111 wireless network adapter to my router) - still no luck. In the end I raised a call with Memeo and had to prove to them I'd purchased the NAS and was the rightful owner of the hardware and they emailed me back a product key.
Shame I had to spend all that time !
In hindsight, I should have gone direct to Memeo :idea: Only took two emails to get a product key emailed back, whereas several emails(2 days) back and forth with Netgear 2nd level support.
....by the way I have 1GB of online data storage using the Memeo Premium software. Not much :shock: but better than nothing :) - ColonelPanikAspirantIt took a restart of Memeo to find the NAS after initially showing the same behavior plus saying the trial period expired even though it was the first installation. Thanks again to LordRhythm for letting me know the software was posted and to others who offered to post it.
- m1byoAspirantI have just managed to get my ReadyNAS Duo V2 working through the network switch.
I had turned off UPnP as it is not enabled on the router and it was not needed in my setup.
Unfortunatley this meant that the memeo software would not autoactivate. The log file showed that the device was being detected but seemed to struggle getting identification.
Enabling UPnP and then restarting Memeo seemed to solve my problems.
Thanks for your help on here.
Ian
