infini_raid
Aug 18, 2011Aspirant
NV+ Power Supply goes up in flames, now what?
The power supply incl. the motherboard are gone, looks like the disks (2) are not damaged.
What's the best and cost-efficient way to retrieve the data?
No warranty left.
Cheers.
No warranty left.
Cheers.
- PapaBear1ApprenticeDown load SeaTools from the Seagate website. They offer both a version that runs in Windows and a DOS based version. The DOS based version when downloade is an .iso file which must be used by a program like Image Burn to create a bootable CD. (It can also be used to create an image of a CD/DVD as well as burn an image to CD/DVD).
The Windows version is easier to load and run, but the DOS version has some advanced tools that can come in handy. I normally use the Windows version installed on this PC, but also have the DOS version. - infini_raidAspirantI've run the SeaTools, connected the drive directly to my windows xp box.
Tests didn't find anything. Now the big question is, is there a way to manually copy the data from the drives
to my windows box? - mdgm-ntgrNETGEAR Employee RetiredOn Windows there are a few recovery programs you can try since you only had two disks in your NAS. One option would be R-Linux as pointed out in Mounting Sparc-based ReadyNAS Drives in x86-based Linux
