mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Browse in the Raidar program, I immediately see the ReadyNAS's folders. I then access the Music Folder on the PC (running Windows 7 Home Premium) but when I drag a file over from there to the media folder on the ReadyNAS, sometimes it copies okay, other times it copies the album name but no files and other times it copies nothing, in both the latter cases I get an error message saying "There is a problem accessing \\192.168.01.06\media".
I wonder if some kind soul could help me here, as it's really beginning to annoy me now?
Cheers,
Martin.
Cheers,
Martin.
- ONESIMUSAspirantTry with your antivirus software turned off.
I assume you know that the files you are copying are virus-free.
Some antivirus programs causes a very large delay on large files and result in failed file copying. - ONESIMUSAspirantA few more options to try:
turn OFF Jumbo frames, if you have it on (if this works, you have incompatible NICs with Jumbo frames)
try another switch between your computer and the ReadyNAS (if this works, your switch probably has bad memory in it) - ArgorAspirantim having the same problem, just connected it up today and did the firmware upgrade, copying is random before a hang on a file. Sometimes waiting before hitting the try again button helps but not often. Have to either skip or cancel, can then copy the file as a single ok. doesnt seem to matter what size the file is.
version 4.1.6
windows 7 home premium, wireless 802.11n
Billion BiPAC 7300N - rick_brewerAspirant
Argor wrote: im having the same problem, just connected it up today and did the firmware upgrade, copying is random before a hang on a file. Sometimes waiting before hitting the try again button helps but not often. Have to either skip or cancel, can then copy the file as a single ok. doesnt seem to matter what size the file is.
version 4.1.6
Billion BiPAC 7300N
Do you have any luck deleting the snapshot to get the copy to complete? - ArgorAspiranthavent set up any form of backup/snapshot yet.
just trying direct connect now.
Copied 9gb of pictures roughly 1mb in size each with no problems.
Moved onto movies and struggling to get anything to copy. Interesting to note that when i select multiple files for the copy it nearly always fails but a single will mostly work.
getting speeds b/n 8-9 MB/sec connected with cat 6. - mdgm-ntgrNETGEAR Employee Retired
Argor wrote: havent set up any form of backup/snapshot yet.
What standard file protocol are you using? - ArgorAspirantwindows 7 home premium. not sure what you mean by standard file protocol
- mdgm-ntgrNETGEAR Employee RetiredLike CIFS, AFP, NFS etc. I guess you're probably using CIFS. I'm not sure what'd be causing the problem though.
- ArgorAspirantahh yeah CIFS is the one
- mjcairneyAspirantJust in case you thought I had lost interest in this thread, especially after starting it, this is just to say I have been working away from home since Sunday, with no internet access, however I am back now.
Cheers,
Martin.
