sunsina's avatar
sunsina
Guide
Dec 28, 2014
Pydio6 is already avaliable but not portable to OS 6.2.2
I upgraded my readynas to OS v6.2.2, then I installed the PyDio through Apps, in this OS version it only installs PyDio v5.2.3.
While PyDio6 is for several weeks out with major improvements, I tried to upgrade PyDio from version 5.2.3 to version 6 through
PyDio's web interface.The upgrade does not work with the PyDio6 PC Sync application, It seems its REST addon does not work.
Anyway is there any plan to include new working PyDio6 in the ReadyNAS OS 6.2.x repositories.
How about upgrading the PHP version to the latest one since uploading large files (more than 2GB) is not supported in the PHP version
that is bundled with ReadyNAS OS 6.2.2
Thanks
  • Will provide it to you but other php addon like owncloud will no more work
    Envoyé de mon iPhone en utilisant Tapatalk
  • Thanks for your new pydio package
    infact I could not install it on readynas OS.6.2.2
    and i get following error
    # dpkg -i pydio_6.0.1_all.deb
    (Reading database ... 29994 files and directories currently installed.)
    Preparing to replace pydio 6.0.1 (using pydio_6.0.1_all.deb) ...
    --2015-03-04 09:48:30-- http://www.dotdeb.org/dotdeb.gpg
    Resolving http://www.dotdeb.org (http://www.dotdeb.org)... 195.154.242.153
    Connecting to http://www.dotdeb.org (http://www.dotdeb.org)|195.154.242.153|:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 5299 (5.2K) [application/octet-stream]
    Saving to: ‘dotdeb.gpg.3’
    dotdeb.gpg.3 100%[===============================================================
    2015-03-04 09:48:31 (106 MB/s) - ‘dotdeb.gpg.3’ saved [5299/5299]
    OK
    Unpacking replacement pydio ...
    dpkg: dependency problems prevent configuration of pydio:
    pydio depends on php5-gd (>= 5.6); however:
    Version of php5-gd on system is 5.4.36-0+deb7u3.
    pydio depends on php5-pthreads; however:
    Package php5-pthreads is not installed.
    dpkg: error processing pydio (--install):
    dependency problems - leaving unconfigured
    Errors were encountered while processing:
    pydio
    Would you mind let me know how can I solve this issue?
    Thanks
  • Bump!
    I have no clue how to properly install pydio6 package from Community Dropbox [pydio_6.0.1_all.deb] (it does not install due to dependency problems, I tried several times) I am wondering if there is any better way to have PHP5.6 coexist with older versions of PHP and get pydio installed to work with PHP5.6?
    Thanks
  • super-poussin wrote:
    the version is in my community dropbox
    The DropBox version has some complication and does not install
  • I'm on 6.2.4 now and the problem is still the same
    /apps# dpkg -i /data/Documents/pydio_6.0.1_all.deb
    (Reading database ... 32256 files and directories currently installed.)
    Preparing to replace pydio 6.0.1 (using .../Documents/pydio_6.0.1_all.deb) ...
    converted 'http://www.dotdeb.org/dotdeb.gpg' (ANSI_X3.4-1968) -> 'http://www.dotdeb.org/dotdeb.gpg' (UTF-8)
    --2015-07-16 20:18:58-- http://www.dotdeb.org/dotdeb.gpg
    Resolving www.dotdeb.org (www.dotdeb.org)... 195.154.242.153
    Connecting to www.dotdeb.org (www.dotdeb.org)|195.154.242.153|:80... connected.
    Saving to: 'dotdeb.gpg.6'
    dotdeb.gpg.6 100%[===========================================================>] 5.17K --.-KB/s in 0s
    2015-07-16 20:18:58 (114 MB/s) - 'dotdeb.gpg.6' saved [5299/5299]
    OK
    Version of php5-gd on system is 5.4.41-0+deb7u1.
    pydio
    Any way to update php manually? I would like to replace Owncloud with Pydio.
    Thanks
    • Retired_Member's avatar
      Retired_Member
      Hello,
      I have the same issue, I followed the discussion tried what's on it, and I'm still unable to install Pydio 6.0.8 on a ReadyNAS 516 OS 6.2.4.
      Any ideas?
      In advance, thank you!
      Best.
        Retired_Member
        I have succesfully install php 5.6, but I still can't install Pydio
        root@Grp-M_NAS:~# php --version
        PHP 5.6.12-1~dotdeb+7.1 (cli) (built: Aug  8 2015 01:28:25)
        Copyright (c) 1997-2015 The PHP Group
        Zend Engine v2.6.0, Copyright (c) 1998-2015 Zend Technologies
            with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2015, by Zend Technologies
ProSupport for Business
