perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4gb file, it starts out ok and will copy around 1gb of the file at 31MB/second but then the connection drops out completely and I get an error message saying:
There is a problem accessing Z:\....
Make sure you are connected to the network and try again.
Now I've obviously mapped drive Z: to the box and when I say it drops out, I can still ping it's IP address. I have tried both NIC's with different cables and in different ports on the router with exactly the same result every time. I am running two other buffalo NAS boxes off the same router and they are working fine.
I can view the files etc over readycloud and check it's performance without problem and in reasonable time, but then as soon as I copy a file over in explorer, readycloud all but freezes and wont let you navigate through the various screens. And once I try to copy a file across I can still view files and directories on the box in explorer, albeit it takes about 30 seconds or so to load each directory which is ridiculous, but before attempting to copy each directory will load almost instantly as you would expect.
Any ideas?
Any ideas?
- Mace_WindooAspirantThanks for the feedback. I posted the release here for users that are following this particular thread.
- chirpaLuminarySo edit your post and make it clear that while it tries to address btrfs issues, it also introduces USB problems, so if people use USB drives, they should wait for (another) 6.1.5 release...
Here, I fixed your left hand, but I had to cut off your right hand in the process.. - Mace_WindooAspirantOnce again, thanks for the feedback. I'll get back with more details once I have them.
- Mace_WindooAspirantThis thread has been unlocked. Please feel free to post your feedback on the filesystem changes that have been made to 6.1.5. For the USB 3.0 issues that have been described, we are still looking into root cause on this.
- chrheiLuminary
Mace Windoo wrote: This thread has been unlocked. Please feel free to post your feedback on the filesystem changes that have been made to 6.1.5. For the USB 3.0 issues that have been described, we are still looking into root cause on this.
After a factory reset all seems to be good, but defrag doesn't work and my readynas102 looks up. USB 3.0 is working with a 30gb thumb drive. The virus scanner seems to use all cpu resources in many cases. - Mace_WindooAspirantDo you have a specific error for the defrag issue and can you describe the lock ups you are experiencing?
- chrheiLuminary
Mace Windoo wrote: Do you have a specific error for the defrag issue and can you describe the lock ups you are experiencing?
No, the NAS is just getting unresponsive, therefore I can't access the device either through the Web interface nor through ssh. And after a forced reboot (power of /on ) the logs do not show something interesting. - Mace_WindooAspirantJust to be clear. You are saying that the NAS becomes unresponsive during defrag? Is the system performing any other operations, such as rebuild at the time?
- Jobber72Aspirant
chrhei wrote: Mace Windoo wrote: Do you have a specific error for the defrag issue and can you describe the lock ups you are experiencing?
Same here and we're not the only one. The performance is now even worse than with 6.1.4. Locks up continuously, becomes unresponsive but sometimes comes back online after 12 - 15 minutes. I let it copy over night and in about 8 hours only roughly 200Gb were copied back....
Here is what I wrote about it in the thread about the 6.1.5 release as a reply to what dishmagic66 wrote.... (And yes, I ordered another NAS from another company yesterday and I will eBay the p.o.s. that the RN104 is. Never a Netgear product for me again.)
Re: 6.1.5 locking up allso
Postby Jobber72 » Thu Jan 02, 2014 9:23 pm
> dishmagic66 wrote:
> The subject says it all.......
> I copied a couple of cdrom iso''s to the nas and then then frontview disconnected and network access was down.
> It lasted about 10 15 minutes before it was back online.
> This is sad..... Will whe have to factory reset again with the next firmware?
I can confirm this. Updated via frontview to the newly released 6.1.5 firmware, did a factory reset (I had already saved all my data to external drives (7Tb space) hooked up to my PC). The system started fine, reconfigured everything the way I want it and started uploading the data back. I am not even at 400Gb of the roughly 4.9TB I need to put back and already the unit hung itself at least 8 times. (It is hanging as we speak) Like dishmagic66 states; after roughly 10 - 15 minutes it will unfreeze again and the upload will continue.
In short: The problem has NOT been fixed, it has been made worse. I only decided to try 6.1.5 as this would solve the problem. I'll now just bite the bullet, shelve out extra money and get me a NAS that actually works (hint: NO MORE NETGEAR)
Somebody else already said this, but is there ANY quality control at Netgear? These type of problems are unacceptable.
And...
Re: 6.1.5 release
Postby Jobber72 » Thu Jan 02, 2014 9:55 pm
Anyone interested in buying a RN104 (without the disks) in original packaging. Bought in May 2013. "Good as new". (Just bought myself another NAS from another manufacturer as I am fed up with the problems with the RN104) - chrheiLuminary
Mace Windoo wrote: Just to be clear. You are saying that the NAS becomes unresponsive during defrag? Is the system performing any other operations, such as rebuild at the time?
It's working very reliable for me, except for defrag. No other task is running when I start defrag. But to be honest my NAS is working CMSimple and Cups, also reliable.
