TCHol95's avatar
TCHol95
Guide
Jun 08, 2016
ReadyNAS 2120 will not sync with AD - Time offset too large
ReadyNAS 2120 stopped syncing with AD.  Firmware is 6.5.  Error is "Time off set between this system and ADS server is too large", but there is no time difference.
  • Hello list, I have the same problem, when I upgrade the fireware the Ready Nas do not sync with AD, I have a temporal solution.
    1-  cd /var/readynasd
    2-  systemctl stop readynasd
    3-  rm db.sq3
    4-  net cache flush
    5   sqlite3 /var/readynasd/db.sq3 'delete from "$home_folder";'
    6-  systemctl start readynasd
    And everything is ok, I can reboot the system and all is ok, but but, I think the ReadyNas try to sync every 12 hours, because when I loging in the web tomorrow for exmple, back the problem again, and I have to repeat the step.
    Definitly somebody have a solution for this problem.........Is not easy repeat the steps every day
    • TCHol95's avatar
      TCHol95
      Guide
      For some reason mine started allowing access, but it still won't sync with AD, or at least the error is saying it won't.  I'll have to give your workaround a try.  I find as a rule these ReadyNAS units sometimes don't eagerly sync with AD.  Out of all of them I've set up only one has does a sync with AD without issue.
      • comando's avatar
        comando
        but there must be a solution, it is not easy every day to run the procedure
  • Same problem with Ready NAS 3138 and 204 and sync with Active Directory
    La diferencia horaria entre este sistema y el servidor ADS es demasiado grande. Sincronizar la hora con el servidor AD.<br />Error in prep join domain
    Code: La diferencia horaria entre este sistema y el servidor ADS es demasiado grande. Sincronizar la hora con el servidor AD.<br />
    Datetime: 09:37:15 06/13/2016
    • TCHol95's avatar
      TCHol95
      Guide
      I love how you get these emails from Netgear asking if you got the answer you needed.  They are interesting in that there's no option for responding with a resounding NO.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Are they synced to the same time server? You should make sure that both devices are getting time from the same place. Are you still getting this error?
      mdgm-ntgr
      Did my previous message resolve your problem?
      • TCHol95's avatar
        TCHol95
        Guide
        Thus far it's been ok even though I haven't change a thing.
ProSupport for Business
