Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all,
Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of dsk).
Checking drive in pc, it was never formatted by the unit.
So the next step was to OS restore or factory restore to force a format BUT holding the reset button and powering on device does not result in the 2 disk LEDs coming on (as holding the power button on boot does) and no matter when I release the reset switch 5 - 40 seconds the device just seems to boot normally to return to error state 3.
Its almost as if I'm missing something totally obvious!! As anyone experienced this behavior? Do. Need to return device as switch is broken???
Thanks in advance
Thanks in advance
- mdgm-ntgrNETGEAR Employee RetiredYes. It would also be why it came up with "corrupt root"
- CrookzAspirantTFTP Boot recovery would repair the flash? Do I just put it in this mode and wait?
- mdgm-ntgrNETGEAR Employee RetiredAre you able to try a different disk to see if that makes a difference?
Don't do a boot recovery unless support (http://www.readynas.com/support) requests you to. If you have a faulty unit return it to your seller in exchange for a new one as NetGear replacements are refurbs. - CrookzAspirantUnfirtunately not, though a faulty drive wouldn't prevent me from resetting
I would have thought - CrookzAspirantUpdate: returned the device, bought a duov2 everything set up now , thanks for the help!
- mdgm-ntgrNETGEAR Employee RetiredGreat!
Hope you like the new web-interface of the Duo v2. - splyfofAspirantWhat about trying a 30/30/30 second reset.
Just did, now its working with the disk.
30/30/30 is done by pressing the reset button when the unit is on AND holding it there for a full 30 seconds.
Still holding the reset button down, power down the NAS.
Keep holding it for a full 30 seconds, and then, while still holding the reset button down, power up the NAS.
Then hold the button for an additional 30 seconds and THEN let go.
You will have been holding down the button for a full 90 second period, and this will usually reset just about any gadget around.
Try it. - StephenBGuru - Experienced UserProblem was resolved 15 months ago - locking the thread.
