motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi,
I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed:
Fri Oct 12 17:12:13 WEST 2012 Problem encountered while updating your ReadyNAS device.
These are the ReadyNAS details:
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.6 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Other than that, everything else seems to be working fine.
Thanks
MT
Thanks
MT
- motah33Aspirant
readynas:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 361M 1.5G 19% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 462G 272G 190G 59% /c
readynas:~#
readynas:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 256000 10697 245303 5% /
tmpfs 7073 1 7072 1% /USB
/dev/c/c 15204352 111733 15092619 1% /c
readynas:~# ls -la /tmp
total 123308
drwxrwxrwt 4 root root 4096 Oct 21 06:09 .
drwxr-xr-x 22 root root 4096 Oct 21 06:10 ..
drwxr-xr-x 2 root root 4096 Oct 21 05:59 addons
-rw-r--r-- 1 root root 206611 Oct 18 06:04 config.zip
-rw-r--r-- 1 root root 13 Oct 21 06:09 .dhcp_server
drwxr-xr-x 2 root root 4096 Oct 21 04:52 log_zip
-rw-r--r-- 1 root root 62948864 Sep 20 19:01 RAIDiator-4.1.10
-rw-r--r-- 1 admin admin 10 Oct 21 06:40 ttt.log
-rw-r--r-- 1 admin admin 62943744 Oct 21 06:02 update_file - mdgm-ntgrNETGEAR Employee RetiredHmmmm. Looks like update_files is probably 4.1.9.
Please do e.g.
# rm /tmp/update_file
Can you also do
# cat /var/log/raidiator_version
# cat /.cf_update_in_progress - motah33Aspirantcat /var/log/raidiator_version
RAIDiator!!version=4.1.6,time=1247518584
The second command gives me:
readynas:~# cat /.cf_update_in_progress
cat: /.cf_update_in_progress: No such file or directory - motah33AspirantYes, I did try with 4.1.9 too which might explain the update_file. It's been deleted.
- mdgm-ntgrNETGEAR Employee RetiredI don't recommend 4.1.9 due to an ownership issue. That's why I suggested deleting that.
What's the output of the following?:
# dd if=/tmp/RAIDiator-4.1.10 skip=1 | md5sum - motah33Aspirant
122946+0 records in
122946+0 records out
62948352 bytes transferred in 9.172726 seconds (6862557 bytes/sec)
26d7138fdc05f30131ab4792cc0feb27 - - mdgm-ntgrNETGEAR Employee RetiredGood.
Well you could try
# echo /tmp/RAIDiator-4.1.10 > /.cf_update_in_progress
# reboot - motah33Aspirantok.. rebooting...
- mdgm-ntgrNETGEAR Employee RetiredIf all goes well the 4.1.10 update should take place now. Just wanted to make sure you had a good copy of the firmware update.
- motah33AspirantBooted and back in as root...
