vaprasad's avatar
vaprasad
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6.  Unable to access any of my shares.  Web indicates "No volumes exist.  NETGEAR recommends that you create a volume before configuring other settings.  Navigate to System -> Volumes page to create a volume."
From the Admin page, error shows:
"Remove inactive volumes to use the disk.  Disk 1,2,3,4,5,6"
Admin System Volumes page showing all 6 bays as red
"Volume is inactive or dead".
How can I recover my volume? What files do I need to attach for troubleshooting? I've downloaded the logs zip file.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    vaprasad
    Can you download the full logs and send it to us via PM? You can also email [email protected]
    We may need to check if the array can still be mounted or if it will need data recovery.
    Note: Data recovery charges may apply.
    HTH
    • vaprasad's avatar
      vaprasad
      Thanks Marc,
      I just sent the log file via email.  The PM option wouldn't allow me to attach the log file.
      Thanks,
      Vijay
      • StephenB's avatar
        FWIW, the usual method is to put the zip into cloud storage (dropbox, etc), and PM a link.
    • vaprasad's avatar
      vaprasad
      Tech support said the device is old and no longer supported.
      What steps can I take to troubleshoot?
      So far, I've run a disk test which indicated:
      Disk test failed in channel 3.
      I powered off the unit and replaced disk 3.
      Web interface still shows my volume as dead or inactive and still shows disks 1,2,4,5,6 in red and still tells me that I need to remove inactive volumes.
      The device was configured with RAID 6, so I'm confused that it is not trying to rebuild the volume at all.
      • StephenB's avatar
        Not only that, they never supported OS-6 on legacy NAS like the Pro-6.
        It sounds like you have no backup of your data - is that correct?
        Did the mods find anything in the log zip?
        Sometimes the volume gets out-of-sync.
ProSupport for Business
