kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24
In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2)
Windows also reports this and the total grows by several hundred GB every day, even though I am not adding anywhere near that total to the NAS. However when I go into windows explorer and check the properties for each share they total 1092GB of disk space used.
anyone have any ideas where the phantom disc space usage is coming from?
- fastfwdVirtuoso
kenzok2002 wrote: anyone have any ideas where the phantom disc space usage is coming from?
If you have SSH access to the NAS, this command will show the size of each directory immediately below the root directory (plus a grand total):du /* -csh
What is the output of that command? - StephenBGuru - Experienced UserAre you using Windows 8?
If so, you might try 4.2.25. It has a fix for "SMB allocation roundup" which you might need.
Also, do you have the recycle bin enabled? - EtzAspirant
StephenB wrote: Are you using Windows 8?
If he uses Windows 8 he shouldnt have a problem and dont need that fix.
It only affects windows 8.1 users.
Which doesnt mean it wouldnt be advisable to keep NAS up to date, unless there is some known bugs in newer firmware. - kenzok2002AspirantYes it is Windows 8 I will try 4.2.25
To respond to the other poster I do not have SSH... - kenzok2002Aspirantcorrection some of my machines are windows 8.1 and some are windows 8
- EtzAspirant
kenzok2002 wrote: correction some of my machines are windows 8.1 and some are windows 8
Then I would also recommend you to upgrade your NAS to 4.2.25 as StephenB suggested above.
Also, as Windows 8.1 is a free update for Windows 8 users, you probably will run 8.1 on all machines at some point and then you will definately have that issue. - kenzok2002AspirantOk updated to 42.25 and its still showing 81% full...
I am also running Egnyte Add-on, which is an old version they have told me to update... anyone have any other ideas? - EtzAspirant
kenzok2002 wrote: Ok updated to 42.25 and its still showing 81% full...
It wont Fix anything in Frontview but in Windows explorer view.
Youre Volume is probably 81% full as it shows.
Do you have Recycle Bin enabled on shares?kenzok2002 wrote: I am also running Egnyte Add-on, which is an old version they have told me to update... anyone have any other ideas?
Not sure about this maybe someone else can comment?
I dont use Egnyte myself. - kenzok2002AspirantWhere would I locate the setting for the Recycle bin?
- mdgm-ntgrNETGEAR Employee RetiredAlso, do you use private home shares?
Do you have any Mac machines and if so, do you backup to the NAS using Time Machine?
