RL57
Dec 28, 2017Guide
Reboot ALWAYS fails after firmware upgrade on ReadyNAS RR4312X
Hi, I've just upgraded our NetGear ReadyNAS RR4312X from 6.8.0 to 6.9.1 and actioned a reboot using the webUI after the upgrade. However once again (this happens after every FW upgrade), the ...
OOM-9
Jan 11, 2018NETGEAR Expert
There are limited units that have encountered this issue in the past. We found from past cases where the issue can happen with a reboot when the unit has been powered on for more than 3 weeks. It would be common for most users to encounter the issue durring firmware update since these rackmount units (RR3312/RR4312) do not go through regular power (reboot) cycles.
Are you able to provide remote access to this unit so we can investigate your unit?
You can enable remote access from System -> Settings -> Support -> Secure Diagnostics Mode and PM me the 5-digit number.
- scottonaharleyJan 25, 2018Aspirant
I have two 4312Xs that exhibit the same behavior. As a matter of fact I am now leaving to drive to the remote site to power cycle the unit. Should I email the logs from both or is this an adjustment to the bios that requires Netgear remote access?
- OOM-9Jan 25, 2018NETGEAR Expert
You can provide us the logs if you gather them.
Otherwise, we have some lab units that are experiencing the issue that we are currently investigating.
- StephenBJan 25, 2018Guru - Experienced User
I am wondering if simply rebooting the NAS before doing the upgrade would be an effective workaround.
