Kwilk6
Dec 11, 2016Aspirant
RN104 inaccessible and displaying btrfs_biomerge_bio_hook+a4 message
Model: RN10400 Firmware: 6.5.1 OS: Windows 10 Environment: Small Office Home Network Installed Storage: 4 x 4TB Hard Drives - 1 volume Issue: NAS unavailable. Hangs during bootup and displays b...
Kwilk6
Tried booting into Volume Read Only mode from the boot menu and the boot process stops at the same point as a normal load, at right around 25 to 27%, and then displays the same btrfs_biomerge_bio_hook+a4 message.
mdgm-ntgr
Dec 11, 2016NETGEAR Employee Retired
Do you have a backup of your data?
- Kwilk6Dec 11, 2016Aspirant
Not all of it. I was using this NAS as a holdover for some data that was not being backed up until another NAS was ordered to store it.
Is this possibly a snapshot issue? Should I attempt to turn them off?
- mdgm-ntgrDec 12, 2016NETGEAR Employee Retired
Turning off snapshots is not going to get the system out of this state.
Sounds like you should contact support. There would be some costs involved with looking into this. It could end up being a data recovery situation.
- mdgm-ntgrDec 27, 2016NETGEAR Employee Retired
I understand that you have reset the unit back to factory default (wipes all data, settings, everything).
