jackburton
Jan 11, 2017Tutor
RN2120v2 - Can't (completely) replicate settings between two readynas using Configuration Backup
Hi all,
i have to set up several ReadyNas 2120v2 with same settings, i have to do this in an isolated subnetwork (no internet) so i'm using "Configuration Backup" in System menu.
I downloaded the "configuration archive" from the first ReadyNas, checking "Everything" button.
So i uploaded the configuration file to a new ReadyNas previously upgraded with the same firmware of the first ReadyNas (6.6.0), using the "Restore" function.
After the reboot, i noticed that the ReadyNas restored hasn't fully configured like the first ReadyNas.
While Shares, accounts and active services are replicated, Host name and Network settings remain unchanged.
Any suggestions would be appreciated.
Thank you.
And I think there are some others - last time I did this the maintenance schedule was not restored either.
Neither the OS 6 user manual nor the the kb article [ https://community.netgear.com/t5/Using-your-ReadyNAS/Backing-up-configuration-OS6/td-p/1161971 ] even hint at this.
This is bad
jackburton wrote:
This is bad
I found it annoying, but not fatal - since I knew what the settings were supposed to be.
https://community.netgear.com/t5/ReadyNAS-Beta-Release/Backup-restore-settings-bug/m-p/1148507/highlight/true#M8769 gives more info on what is restored, but not a lot of details on what isn't. I thought there was at least one other thread on this topic, but I am not finding it now.
Hi,
any news ?
Thanks,
Regards
