blw
Sep 26, 2017Aspirant
RN3220 unable to boot after power outage
I have a ReadyNAS RN3220 that is unable to boot after a power outage. There is no output on the console connection and I cannot get in to the boot menu with or without disks. The ReadyNAS does not show up in RAIDar. The network connection stays up for about 2 seconds before disconnecting and connecting again. I have tried reseating the RAM and unplugging the CMOS battery for a while but this did not help. The power light is blinking green. I have also tried the USB recovery but this does not seem to do anything either (the activity light on the memory stick blinks once at boot then stays off). The unit is under warranty but I was told that problems caused by power outages were not covered...
Any help is greatly appreciated!
- SandsharkSensei
Was the NAS protected by an UPS and shut itself down gracefully when the UPS ran down, or did it shut down suddenly? If the former, then you problem was most likely not cause by "a power outage", but simply by a power cycle. If the latter, it could be that the OS on the drives is bad rather than the hardware. Whichever the case, try booting it with no drives and see if RAIDar shows it with a "no disks" status.
- blwAspirant
Hi Sandshark, the NAS was protected by a line-interactive UPS but the UPS was not setup to automatically shutdown the NAS so it shut down suddenly. I have tried booting with no drives but the NAS does not show up in RAIDar and does not allow me to enter the boot menu or perform USB recovery. The power LED flashes green but nothing else.
IMHO if that resulted in hardware damage, it should be covered by the warranty. You might try support again (and ask to speak to supervisors, etc if necessary).
- blwAspirant
Just a quick update - I managed to get an RMA after a bit of back and fourth with Netgear. Thanks to everyone who replied! (I gave them a link to this post - Maybe that's what persuaded them!!)
