plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi! I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log: rsync: set_acl: sys_acl_...
WhoCares_
Sep 05, 2011Mentor
Then there's your problem. While the ReadyNASis able to write to NTFS partitions it doesn't - due to limitations in the driver used - support all of NTFS's features, most prominently ACLs. To get that support and also speed up your backups to USB drives I'd recommend reformatting the drive using the ext3 or ext4 format. Be aware however that neither of these can be read on a Windows machine natively. You'd need a Linux or a Mac system to be able to read from those drives without buying a special file system driver.
-Stefan
-Stefan
