plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi! I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log: rsync: set_acl: sys_acl_...
mjw1
Sep 10, 2011Aspirant
I had the same problem as you a year back running RAIDiator 4.1.6. The solution was to
1) Install a newer version of the NTFS-3G driver (kindly provided by "WhoCares?"). The good news is that the latest version of RAIDiator now includes an updated NTFS-3G driver so this step should not be needed any more (caveat: I haven't upgraded to try this myself yet)
2) With the NTFS drive connected to your PC, create a folder on your NTFS drive called ".NTFS-3G"
3) Create a file in the .NTFS-3G folder called "UserMapping"
4) Put exactly this text into the UserMapping file and save
5) Safely disconnect the USB drive from the PC (should be an icon in the icon tray to do this)
6) Connect your NTFS USB drive to your readynas and switch on the USB drive
7) Reboot your readynas
After that backups should work with no issues. Even file ownership will copy across correctly.
RAIDiator 4.1.8 includes NTFS-3G 2011.1.15 which supports ACLs.
::S-1-5-21-3141592653-589793238-462643383-10000
