plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi! I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log: rsync: set_acl: sys_acl_...
plingis30000
Sep 21, 2011Aspirant
mjw wrote: Yes. All you are doing is to save a UserMapping file in your usb drive so that the new ntfs driver software knows how to map between Linux and windows users.
Hi!
I generated the ".NTFS-3G" directory and placed the "code" in the file "UserMapping" and it was still problem to go all the way to finish the job.. A bit up in the logs there were some ".doc-files" that has to been removed/renamed and after that the job was finished. I was very happy... It seems that "Microsoft Office"-files causing this problem...?
How to go futher on do you think?
Best,
Magnus
