plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi! I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log: rsync: set_acl: sys_acl_...
mjw1
Sep 21, 2011Aspirant
Also, please ssh into your readynas and run this command:
My readynas prints out the following:
ntfs-3g -help
tera:~# ntfs-3g -help
ntfs-3g 2010.10.2AR.1 integrated FUSE 28 - Third Generation NTFS Driver
Configuration type 7, XATTRS are on, POSIX ACLS are on
Copyright (C) 2005-2007 Yura Pakhuchiy
Copyright (C) 2006-2009 Szabolcs Szakacsits
Copyright (C) 2007-2010 Jean-Pierre Andre
Copyright (C) 2009 Erik Larsson
Usage: ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
Options: ro (read-only mount), remove_hiberfile, uid=, gid=,
umask=, fmask=, dmask=, streams_interface=.
Please see the details in the manual (type: man ntfs-3g).
Example: ntfs-3g /dev/sda1 /mnt/windows
Ntfs-3g news, support and information: http://ntfs-3g.org
