plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi! I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log: rsync: set_acl: sys_acl_...
plingis30000
Sep 21, 2011Aspirant
mjw wrote: So, I'm a bit confused - does you backup now finish 100% successfully or are there errors in the logs?
If there are still errors, please can you post any error or warning messages you saw in the log?
I had errors in the logs but deleted them... I tried to regenerate an error by moving the .NTFS-3G directory and saved a word-file on the NAS and then reboot the NAS but now it goes allt the way and finished by 100 %. When there are no errors in the log I think its hard to start searching?
But there are som major problems:
viewtopic.php?f=124&t=57211
and I think that all these stuff has to do with each other.
Best,
Magnus
