beack
May 12, 2011Aspirant
rsync uid 4294967295 (-1) is impossible to set on...
Hi there.
I have a problem with rsync backup on my ultra 2.
I have some backup jobs running rsync, connecting to a windows machine running the deltacopy rsync server.
Files are copied from the windows machine to the nas.
On firmware 4.2.16 it worked flawless.
After i upgraded to 4.1.17, whenever i run af job, i get a "backup failed" error (though the files are copied!), and the log is full of entries like this:
uid 4294967295 (-1) is impossible to set on [filename]
Can anybody help my to eliminate these errors?
Thanks in advance
/Beack
Thanks in advance
/Beack
- silent_kAspirantThank you so much WhoCares. I appreciate you taking the time to find a work around.
Can you tell me... when a new version of radiator comes out will it automatically overwrite the old version of rsync with whatever version is packaged in radiator? - mdgm-ntgrNETGEAR Employee Retired
Yes, but a bug has been filed for it (at least on Sparc) and it will be fixed so newer Rsync works: http://www.readynas.com/forum/viewtopic.php?p=332968#p332968
Not sure if it's already fixed in 4.2.20 betas or not, but if not hopefully it will be.
