komm_it
Mar 27, 2018Guide
Semantic confusion between SOURCE and TARGET about RSYNC differential backup job…
Hello there, Could someone tell me what should I trust? Should I trust what's written in the ReadNAS Help section "Configure Advanced RSYNC Job Setting" about differential backup that says "Remove ...
- Mar 27, 2018
I have that box checked on my own systems.
If checked, rsync will delete any files on the target that are no longer on the source.
If you are using OS 6.x on the target machine and have snapshots enabled, then you can restore those deleted files from the snapshot.
I agree the wording is confusing.
Mar 27, 2018Guru - Experienced User
komm_it
Mar 28, 2018Guide
I thank you to confirm that what’s actually written in the ReadyNAS help is correct.
I didn’t dare to check the box before hearing from someone using that option.
