joe_schmo
Jun 02, 2018Tutor
Slow login
I have an RN316, a 428, and an Ultra4.
On the 428 and the Ultra4, when I SSH in via Putty, I put i nmy username and then immediately, the password prompt appears.
With the RN316, it takes...
Jun 02, 2018Guru - Experienced User
Do you have disk spindown enabled on the RN316?
- joe_schmoJun 03, 2018Tutor
Nope... although that would have been awesome if it were the case :)
- StephenBJun 03, 2018Guru - Experienced User
Once you do get in, perhaps run top and see if something is hogging the CPU. Maybe also check the disk health, and the fullness of the OS partition.
- joe_schmoJul 17, 2018Tutor
root@NAS:~# btrfs fi us /data | grep unall Device unallocated: 4.39TiB root@NAS:~# btrfs balance status -v /data Balance on '/data' is running 560 out of about 4334 chunks balanced (19676 considered), 87% left Dumping filters: flags 0x7, state 0x1, force is off DATA (flags 0x2): balancing, usage=78 METADATA (flags 0x2): balancing, usage=39 SYSTEM (flags 0x2): balancing, usage=39 root@NAS:~# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 3.1G 779M 81% / tmpfs 992M 0 992M 0% /dev/shm tmpfs 992M 5.3M 987M 1% /run tmpfs 496M 11M 485M 3% /run/lock tmpfs 992M 0 992M 0% /sys/fs/cgroup /dev/md127 37T 29T 7.4T 80% /data /dev/md127 37T 29T 7.4T 80% /home /dev/md127 37T 29T 7.4T 80% /appsAfter 13 days, it's at 87% left on the balance. Any ideas?
