joe_schmo
Jun 02, 2018Tutor
Slow login
I have an RN316, a 428, and an Ultra4.
On the 428 and the Ultra4, when I SSH in via Putty, I put i nmy username and then immediately, the password prompt appears.
With the RN316, it takes...
joe_schmo
Jun 03, 2018Tutor
Nope... although that would have been awesome if it were the case :)
Jun 03, 2018Guru - Experienced User
Once you do get in, perhaps run top and see if something is hogging the CPU. Maybe also check the disk health, and the fullness of the OS partition.
- joe_schmoJul 17, 2018Tutor
root@NAS:~# btrfs fi us /data | grep unall Device unallocated: 4.39TiB root@NAS:~# btrfs balance status -v /data Balance on '/data' is running 560 out of about 4334 chunks balanced (19676 considered), 87% left Dumping filters: flags 0x7, state 0x1, force is off DATA (flags 0x2): balancing, usage=78 METADATA (flags 0x2): balancing, usage=39 SYSTEM (flags 0x2): balancing, usage=39 root@NAS:~# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 3.1G 779M 81% / tmpfs 992M 0 992M 0% /dev/shm tmpfs 992M 5.3M 987M 1% /run tmpfs 496M 11M 485M 3% /run/lock tmpfs 992M 0 992M 0% /sys/fs/cgroup /dev/md127 37T 29T 7.4T 80% /data /dev/md127 37T 29T 7.4T 80% /home /dev/md127 37T 29T 7.4T 80% /appsAfter 13 days, it's at 87% left on the balance. Any ideas?
- StephenBJul 18, 2018Guru - Experienced User
Did you start this balance from the web ui, or from ssh? If the latter, do you recall what parameters you used?
Also, your OS partition is very full. What have you installed on it?
- joe_schmoJul 20, 2018Tutor
WebUI... here are the parameters:
- StephenBJul 21, 2018Guru - Experienced User
joe_schmo wrote:
would that explain the slow balance and the slow rsyncs from it as well?
No it doesn't.
joe_schmo wrote:
WebUI...
When was the last time you ran a balance?
What firmware are you running? Netgear made a change a while back to change the usage threshold (not sure exactly when).
Overall, the usage threshold is defined here: https://btrfs.wiki.kernel.org/index.php/Manpage/btrfs-balance The higher the threshold percentage, the more chunks are re-written.
