joe_schmo
Jun 02, 2018Tutor
Slow login
I have an RN316, a 428, and an Ultra4.
On the 428 and the Ultra4, when I SSH in via Putty, I put i nmy username and then immediately, the password prompt appears.
With the RN316, it takes...
Danthelf
Jul 19, 2018Star
For the sake of it I decided to look in to this further, so in order to find out what was going on I did a packet capture while logging in. The reason for the slowness is because the SSH server will attempt to do a reverse DNS lookup the hostname of the client you're connecting from before presenting you with the password prompt, so if your DNS settings are misconfigured it will have to wait for that to timeout before presenting you with the password prompt.
The reason why I found this to be related to me joining the NAS to my AD domain is simply because at the time I modified my DNS settings to use:
1) My DC's IP
2) google DNS
My DC is currently turned off (this is a home lab) so of course it will not respond to DNS queries. Removing it from the list of DNS servers resolved the issue and logins are now instant.
You can also stop the ssh server from attempting lookups by adding "UseDNS no" to your sshd_config
# echo "UseDNS no" >> /etc/ssh/sshd_config # systemctl restart ssh
joe_schmo
Jul 20, 2018Tutor
This is interesting... but would that explain the slow balance and the slow rsyncs from it as well?
