cero
Jan 02, 2017Aspirant
SMB not active from time to time after power on
Hello
After this RN102 was updated to 6.6.0 we sometimes have SMB access problems. This device is powered down every day using the internal timer service and is powered UP every night for backup purposes. Most of the time the readynas works all right but from time to time, no SMB access is possible. I have to connect to the GUI and go to parameters and I see there the SMB button and of course it is grey. I have to turn it to ON and it turns to green. SMB is operational then and the shares are available from the Domain.
I cannot find any problem in the logs (smbd log says: STATUS=daemon 'smbd' finished starting up and ready to serve connections)
This Nas uses AD for users and is connected to a very small domain, it has no add-ons, no cloud, and no exotic parameters, tested with or without antivirus,
Only internal scheduler is used every day for shutdowns on power up.
Have you any ideas of the problem and how to fix it, I don't want to revert to earlier OS as this is too much of a hassle.
I cant sent the logs if needed.
Thanks for help.
- FramerVNETGEAR Employee Retired
Hi cero,
I think it might be best if you can send your logs first.
How do I send all logs to ReadyNAS Community moderators?
- ceroAspirantHelloI have joined the logs of my RN104 with SMB issues after reboot according to instructions.Note that the problem of SMB button turned to grey instead of green happened on Dec 24th, Dec 30th, Jan 1st and Jan 2nd between 22h (time of powerOn) and 23h59. (I receive an alert at 23h59 when my backup program can't access the NAS using SMB).Thanks for help
- mdgm-ntgrNETGEAR Employee Retired
Can you go to System > Settings > Support, enable Secure Diagnostics Mode and let me know the 5-digit number that you then get?
