vesper76
Dec 07, 2009Aspirant
Somehow broke logger, thereby breaking everything
For background on how I somehow got to this point: viewtopic.php?f=22&t=36105&start=0 I'm moving to this forum, because it's essentially a different question than I started with. The short versio...
Dwarf1
Jan 28, 2010Aspirant
Hi vesper76,
Did you solve your problem ?
I have got exactly the same problem, mysql can't start because the logger don't know the "-i" argument.
If you solved your problem, can you tell me how ?
If someone has got a solution ...
thanks
Dwarf
thanks
Dwarf
