vesper76
Dec 07, 2009Aspirant
Somehow broke logger, thereby breaking everything
For background on how I somehow got to this point: viewtopic.php?f=22&t=36105&start=0 I'm moving to this forum, because it's essentially a different question than I started with. The short versio...
Dwarf1
Jan 28, 2010Aspirant
dbott67 wrote: A firmware re-installation will likely fix the problem. This does not affect your data, however, it will reset your admin password to 'netgear1' and reset the network settings to default settings (DHCP, no jumbo frames, no teaming, etc.):
http://www.readynas.com/forum/faq.php#H ... irmware%3F
Thanks dbott67 for the tip,
Vesper76 tried this method and the problem was not solved.
I'll try too ... the luck might be with me :)
Dwarf
Edit:
I continued some investigations, and I think the problem comes from the BusyBox tool installed in the ReadyNAS Pro.
Here is the output of the Busybox command on my RNDP.
root@Elrond:/ # busybox
BusyBox v1.14.3 (2009-08-12 21:37:19 UTC) multi-call binary
Copyright (C) 1998-2008 Erik Andersen, Rob Landley, Denys Vlasenko
and others. Licensed under GPLv2.
See source distribution for full notice.
Usage: busybox [function] [arguments]...
or: function [arguments]...
BusyBox is a multi-call binary that combines many common Unix
utilities into a single executable. Most people will create a
link to busybox for each function they wish to use and BusyBox
will act like whatever it was invoked as!
Currently defined functions:
less, logger, lzmacat, md5sum, readahead, telnet, udhcpc, udhcpd, unlzma, usleep, vi
I tried to find a new version of the busybox tool with apt-get but no luck.
If the Jedi council reads me, can you help me ? Do you know if a new version of the busybox tool has been released and how to install it ??
Dwarf
