vesper76
Dec 07, 2009Aspirant
Somehow broke logger, thereby breaking everything
For background on how I somehow got to this point: viewtopic.php?f=22&t=36105&start=0 I'm moving to this forum, because it's essentially a different question than I started with. The short versio...
fphredd
Mar 16, 2010Aspirant
I don't know if I have the same or different problem. If it's not the same please let me know and I'll go from there. ReadyNAS Pro shows Squeezebox, but when I try to access it, either through RAIDiator or by going straight through browser <myip>:9000 I am unable to connect. Does this sound like the same issue? If so, can someone please supply 'instructions for idiots' on how to fix it?
Thank you!
EDIT: Fixed, needed to clean the database. Thanks for listening (reading as the case may be).
Thank you!
