vesper76
Dec 07, 2009Aspirant
Somehow broke logger, thereby breaking everything
For background on how I somehow got to this point: viewtopic.php?f=22&t=36105&start=0 I'm moving to this forum, because it's essentially a different question than I started with. The short versio...
bsilva
Apr 27, 2011Aspirant
Hi All,
I got an NVX a couple of weeks ago, promised myself I would behave, but I just could not resist... I had to tinker with it! :D
I got hit by the same logger problem, but I choose a "less drastic" way of getting around it.
Sharing with the world so you have another option, and may choose not to touch the installed software (busybox).
I replaced the /usr/bin/logger symlink to busybox (cd /usr/bin/; rm -i logger; vi logger; #A, copy & paste, ESC : x ; chmod +x logger) by the following script:
This way the -i parameter is ignored, for mySQL and other scripts that try to call busybox/logger with it.
b
#!/bin/bash
while getopts ":st:p:" Option
do
case ${Option} in
s | t | p ) cmdline="${cmdline} -${Option} ${OPTARG}" ;;
esac
done
shift $((${OPTIND} - 1))
busybox logger "${cmdline}" "${*}"
b
