vesper76
Dec 07, 2009Aspirant
Somehow broke logger, thereby breaking everything
For background on how I somehow got to this point: viewtopic.php?f=22&t=36105&start=0 I'm moving to this forum, because it's essentially a different question than I started with. The short versio...
PeterH2
Dec 22, 2011Aspirant
Well, I found a quite rigorous solution fyi. I have set the NAS back to factory default (frontview -> update -> factory default).
Then I did the following:
1. Install php 5.3.8 via the addon (http://readynasxtras.com/readynas-x86-add-ons/php-53-x86)
2. Install mysqlon addon from super-poussin (http://www.readynas.com/forum/viewtopic.php?f=48&t=22853)
The mysqlon addon needs to be installed, because mysql is not running by default
Finally, I have no problems anymore with noflushd (due to the factory reset) and also php 5.3.8 is working and mysql is working! nice right :-)
Now only problem is Apache. I created a share via Frontview called "www"
However, no matter what I write in the httpd.conf [config file of apache] I cannot open: http://192.168.1.101/site.com/
403 Forbidden: You don't have permission to access /site.com/ on this server.
If I go to: http://192.168.1.101/www/site.com/
I only get 404 not found
This is what I have added to my httpd.conf file:
Alias /site.com /www/site.com
<Directory /www/site.com> ## also tried <Directory /site.com>
Options Indexes FollowSymLinks
AllowOverride All
Order allow,deny
Allow from all
</Directory>
[then restarting apache]
When going to: http://192.168.1.101/site.com/
I get this error in Apache errorlog:
"Symbolic link not allowed or link target not accessible: /www"
Of course I have Googled this error as well, and tried it with /c/www/ and with putting +FollowSymLinks in my .htaccess file, and also tried virtual host, but none of this worked.
Any ideas on this?
- Peter
AllowOverride All
Order allow,deny
Allow from all
</Directory>
Any ideas on this?
- Peter
