mrQQ
Jun 11, 2015Apprentice
suddenly started getting fan speed errors
hi,
I run 6.2.4 on RNDU4000, and suddenly started getting errors in log and email:
how to fix this?
Thu Jun 11 2015 9:24:08
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (709 rpm).
Thu Jun 11 2015 9:22:11
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (711 rpm).
Thu Jun 11 2015 9:19:54
Thu Jun 11 2015 9:16:02
Thu Jun 11 2015 9:14:36
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (710 rpm).
Thu Jun 11 2015 9:08:54
Thu Jun 11 2015 9:07:23
Thu Jun 11 2015 9:06:16
Thu Jun 11 2015 9:04:15
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (708 rpm).
Thu Jun 11 2015 9:03:33
Thu Jun 11 2015 9:02:27
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (707 rpm).
Thu Jun 11 2015 9:00:56
Thu Jun 11 2015 8:58:54
Thu Jun 11 2015 8:58:18
how to fix this?
- mrQQApprenticeFYI, the file did not exist, I've echo'ed into it, but I'm still getting the errors...
- StephenBGuru - Experienced UserYou did the restart part of the procedure?
- mrQQApprenticeYes. Did not try restarting whole NAS though.
- mrQQApprenticeAny other options? :(
- mdgm-ntgrNETGEAR Employee RetiredIt could take some minutes for the change to take effect. So you still keep on getting these alerts regularly?
- mrQQApprenticeYep, still getting them every night as the temperature drops and the fan slows down.
Perhaps the location is different in my system? As I've mentioned the file did not exist? - StephenBGuru - Experienced UserThe file doesn't normally exist. It's an override (e.g., if the system sees it, it is supposed to use it instead of the hard-wired minimum).
- mrQQApprenticeok, so perhaps a reboot is in order?
or, perhaps, I need to set specific permissions for the file?
is the name exactly correct? - mrQQApprenticefwiw, reboot did not help.
- mrQQApprenticeI think I figured this one myself.
I had fancontrol installed from early versions where 6 OS did not support legacy fan control. And it worked really well for me since I had NAS running in my living room and needed it to be quiet. Now I removed fancontrol package and speed jumped to 1700 which is fine since it's hidden away somewhere.- ATCISTutor
I hadfancontrol installed from early versions where 6 OS did not support legacy fan control. And it worked really well for me since I hadNAS running in my living room and needed it to be quiet. Now I removedfancontrol package and speed jumped to 1700 which is fine since it's hidden away somewhere.I think I may be experiencing the same (or similar) issue that you had here, only mine was delayed until I upgrade to OS6 version 6.4. If you have time, would you mind checking out my post found here https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/td-p/990867 and tell me what you think? If you concur, would you mind elaborating on the proper method of removing the fancontrol package as you did?
Thanks in advance!
- petermacApprenticeSame issue here, upgraded Pro 6 to FW 6.4 and now the system fan is not spinning unless the system temps gets over 70C. I have tried creating the file and restarting the system and it doesn't do anything that I can tell
