Cazzbags's avatar
Cazzbags
Volume: System volume root's usage is xx%. This condition should not occur under normal conditions.
Hi all
I've found a few miscellaneous posts about similar problems but none that seem to relate here.
I'm getting the log error:
Volume: System volume root's usage is 92%. This condition should not occur under normal conditions. Contact technical support.
This morning it was at 82%... increasing steadily since then. It now is marked as volume critical.
I don't have any apps installed. I tried disabling antivirus and rebooting and then turning it back on as another post suggested. Still no go.
I paid for some support and have been calling in and raised a case but after several hours there doesn't seem to be a solution and the % is rising.
Any ideas?
  • Hi I seem to be having the same issue.  I'm running firmware 6.9.5.  I've tried ssh to the device and using the command df -i i get the following in putty:
    As far as I can tell from this I don't seem to have a problem as the highest usage is 23%.  Can anyone provide any better checks for diagnosis?  I'm not an SSH expert so step by step help welcome!
