- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear wax218- 2.4GHz radio random disabling
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a problem with the Netgear WAX218 router. After switching the channel width to 20MHz / 40MHz, my radio fades to 2.4GHz. When I have the 40MHz channel set my 2.4GHz radio turns off randomly but works fine after a while. The router has the latest version of the system. I added the link https://drive.google.com/drive/folders/1KX53Wtq5KmL_5ByiGRmoRHUyWrxszP7o?usp=sharing to the screenshots of my access point settings. Does anyone have an idea for this? I will be grateful for the answers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear wax218- 2.4GHz radio random disabling
Was everything working fine before?
Let us try this. Kindly disable 11ax mode then check if the same problem will occur.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I have had such problems for some time. On the 40MHz channel it works fine after turning off the 11ax mode. Now I will test it on the 20MHz / 40MHz setting. I will let you know what and how.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Niestety w trybie 20MHz / 40MHz radio 2.4GHz nie działa z wyłączonym trybem 802.11ax. Zauważyłem również, że czasami prędkość sieci LAN wynosi 100 Mb / s zamiast 1 Gb. Z reguły jest to 1Gb.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us try this. Perform a factory reset on your WAX218 then reconfigure the settings from scratch. Observe if the same issue will occur.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have already tried restoring the firmware to the factory settings and it did not work. I was also doing a downgrade and it was useless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This needs further investigation. I suggest you to open a support ticket with NETGEAR Support here at anytime. Kindly state that status of your WAX218 and the troubleshooting steps done to isolate the problem as well as you can include a link to this thread.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has this issue been resolved? I am experiencing the same issues with my WAX218.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Found out from the NETGEAR Support Team that you have an ongoing support ticket with them regarding your concern. You may want to share the progress of it here.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I reported the problem to Support and I have been talking with them for 2 months. I was sending them a config from the device + and I performed Wifi visibility tests on 2.4GHz. At the moment, they are to pick up the devices to be tested by Netgear employees from L3 Support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
