Dj_Scott
Jan 27, 2017Aspirant
Splitting WND930 antennas between indoor and outdoor.
Hi!
Question.
I have a bunch of 30X30 sound stages (a metal hangar).
Need to provide internet inside and outside.
Solid connection to up to 20-50 clients.
I want to mount WND930 inside the hangar using it's internal antennas to provide Wi-Fi inside.
And exted external antennas to outside and use these to provide Wi-Fi outside.
Does this make any sense? I'm truing to save an extra acsess point for to locations.
Can I split 2 external antennas 2,5 GHz and 5 GHz inside and 2 outside. Will this work?
Wat's it's outside range in countryside? 2 antennas 4 antennas?
Thank you!
Sorry. I can not acsept it as a solution. Beacause nether thre solution notr the explanation why in is "impossible" was provided. And even if it was - you where wrong in the first place. As for the acseptable solution - I went ahead and bought WND930 and tested the seperate antenna placement.
And guess what - it worked. Antennas seperated in to two zones work perfectly!
BTW the final call was to switch the intire operation to Cisco. Just so you know.
- DaneANETGEAR Employee Retired
Hi Dj_Scott,
Welcome to the community! :)
The internal and external antennas of the WND930 cannot be used at the same time. The possible setup that I can suggest are the following:
a. 2.4GHz / 5GHz Point-to-Point Wireless Bridging using internal antennas - This requires 2 WND930 and this will give approximately a 1 mile / 0.75 mile wireless range (2.4GHz / 5GHz respectively). Of course, the 2 WND930 should be within line-of-sight to each other. Kindly read pages 37-39 of the WND930 reference manual here on how to set up Point-to-Point Wireless Bridge.
b. 2.4GHz / 5GHz Standalone access point using external antennas - Since its standalone, it just requires 1 WND930 and this will give approximately 1500 feet / 1000 feet (2.4GHz / 5GHz respectively) wireless range. Kindly read pages 24-25 of the WND930 reference manual here on how to connect external antennas and select the external antenna option via the web-GUI of the WND930.
DaneA
NETGEAR Community Team
- Dj_ScottAspirant
Looking at this router specs I see only 2 bands it operates on.
What's these antennas actually are?
2 antennas 2,4 GHz
2 antennas 5 GHz
If I seperate the antennas like this:
One 2,4 GHz and one 5 GHz antennas inside and
one 2,4 GHz and one 5 GHz antennas outside.
It should wirk. From what I know Wi-Fi tranivers are duplex. So there is no TX-RX destinguished antennas.
