- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300v2 AC1750 Comcast claims it's incompatible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Their newer models have wired speeds of 2.37Gbps and
DOCSIS Channels
16 down x 4 up
32 down x 8 up
DOCSIS Version
DOCSIS 3.0
DOCSIS 3.1
My internet speed plan:
Blast!® Internet Plan
Download speeds: up to 600 Mbps
Upload speeds: up to 20 Mbps
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 369mbps is more realistic for that device on comcast. You might hit a bit faster but you don't really use it over wifi.
I'd look into seeing if there's a cheaper plan around that 200-300mbps for your device.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300v2 AC1750 Comcast claims it's incompatible
- Mark as New
- Bookmark
- Subscribe
- Permalink
What package plan do you pay for from CC?
Upload speeds: up to 20 Mbps Would be well compatible if the ISP speed package was at this level or under.
However you'll need to check the ISPs current supported cable modem list to see if it's supported on there network. Its up to ISP to support the various cable modem brands and models. As time goes on though, they my decide to cut off support for older modems. The C6300 came out in 2014. So getting older for the model modem. Something to check with the ISP.
Has the modem been working with this ISP since you've had it?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your current device can't keep up with the latest speeds
We aren't really having problems. Lag once in awhile. But we're using tvs, smartphones, laptops and desktops without major problems.
"Please note that if you do not swap your Internet equipment, you will not be taking full advantage of the download speeds your Internet plan offers."
It says since we upgraded our internet speed to the speed I already mentioned ("up tp 600...") our equipment can't keep up with the latest internet speeds available to us.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Downloads up to 600
Uploads up to 20"
Not my device (listed in the subject)
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you look at the spec sheet for this modem it supports up to 600Mbps on the down.
Just seems like they are pushing you.
Whats the link show for the supported modem models?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What actual speeds do you pay for?
Reason I ask is that the C6300 when it came out was rated "up to 600mbps". That changes though based on the isp. That's just its max capability that an ISP "could" hit.
More ISP have been requiring docsis 3.1 devices for lower speed tiers. Cox for example has been requiring docsis 3.1 for speeds over 250mbps for a while now. If xfinity changed they're requirements, then it might not support your speeds.
If you're only paying for 200mbps, then you should be fine.
If you're actually paying for 600mbps, its doubtful that your device will get that anymore. The 369mbps you listed, is probably more accurate to what it could hit.
But if you're not using wired device, its pointless to pay for anyway as that router is only going to hit 250-350mbps over 5ghz anyway.
so what actual speeds do you pay for?
Are you wanting faster speeds or more capability?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would test your modem with a wired PC and see if your getting the upgraded speeds. Since they upgraded you and I presume for free, I would power OFF the modem for 1 minute then back ON. Use a wired PC and Ooklas installable speed test app on a PC and see what you find. If your getting 600 on the down then you could keep the modem going until such time as your ISP requires you to get something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
6 | |
3 | |
2 | |
2 | |
1 |
