mr_sf's avatar
mr_sf
cm1150v wall mount?
Can the CM1150v base be removed?
Don't worry... if I remove the base it will be properly ventlated on all sides.   I just want to confirm the base is removable
thx
  • plemans's avatar
    i don't have a cm1150v but both my cm1100 and cm1000 have a torques screw on the bottom that could be used to remove the base. It probably voids your warranty as they really do need that position for airflow or they'll overheat.
  • FURRYe38's avatar
    The base is not removeable.
    thx
    Yes.   It is held on with a single torx screw.  Easy to remove.
    • mr_sf's avatar
      mr_sf
      No....  i just ended up taking the base off and having it stand up on a wall mount wire hanger meant for ties.   the cables are easily routed through the bottom of the hanger.  not elegant, but seems to work.  actually has a little air flow on the wall side.
      Efficcial wrote:
      Were you ever able to find a wall mount??
