× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear 785 - stuck in 'shutting down'
francismartens
This little device was a gem - always working.  Since yesterday, after bringing up the device it immediately goes into 'shutting down' mode
I have been looking at the different posts on this subject in this community but didn't find a conclusive action.
What should I do to make it a gem again ?
Thanks
Model: AirCard 785|AirCard 785 Mobile Hotspot (Retail)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Netgear 785 - stuck in 'shutting down'
Hello Francismartens
Have you tried a factory reset? If you still can not get the device to boot and it is still under warranty I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 3
francismartens
Hi,
Pressing the navigation and power buttion as detailed in
https://kb.netgear.com/25853/How-do-I-reset-my-AirCard-785-to-factory-default-settings
is not helping neither.
Unless there is another way to do a factory reset, I will have to contact support.
Thanks anyway
Francis
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3534 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
