- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Genie - Parental Control Not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear Genie (on both iOS and PC) wouldn't allow me to perform Parental Control.
Genie App on PC is stuck saying "You don't appear to be connected to Internet ..." and "Identifying your Router".
I have done FW upgrade of the router as well as the factory reset but it did not help.
Appreciate any help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are correct! After I downgraded to FW version V1.0.0.56_1.0.18, things are working again. I hope that Netgear takes note of this and fixes this in the next version of the FW.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Genie - Parental Control Not working
Same problem here. Seemed to happen after the firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just downgraded too and everything is working again on the app!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Can you please tell me how you installed the new version. It comes in a zip file. i have a R7300 Netgear and after istalling the latest version, the Parental Control quit working. i have a preteen kid at home who is pretty savy and I need to have web access under control. Please help with the procedure.
thank you very much
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Can you please tell me how you installed the new version. It
> comes in a zip file. [...]
By "new" do you mean "older"? If you extract the files from the zip
archive, then you should get a ".chk" file which is the firmware file,
and an "XXX_Release_Notes.html" file which should include installation
instructions.
> [...] i have a preteen kid at home who is pretty savy [...]
Have the kid install the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks for the reply. No the firmware was installed within the genie app/window. It prompted me to update the firmware, so I did and then the parental control quit working. The kid did not mess with my computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also the version I installed is the new which is firmware version V1.0.0.62. Not sure what was there before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, V1.0.0.62 is the problematic one. I would recommend that you downgrade to one of the earlier version. I downloaded and installed V1.0.0.56 from:
https://www.netgear.com/support/download/
And the Parental Conrol is back on!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank You very much. downloading is not a problem installing is. Should I go through the Netgear website to install it? It was not letting me install after I unzip the file and hit upload. It would say it was reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] The kid did not mess with my computer. [...]
My point was that if the kid is more "sav[v]y", then he might have
more success with the firmware update.
> [...] downloading is not a problem installing is.
And the problem is?
> [...] Should I go through the Netgear website to install it?
What, exactly, does "the Netgear website" mean to you? As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations. Copy+paste is your friend.
> [...] It was not letting me install after I unzip the file and hit
What, exactly, did you get when you "unzip the file"? What, exactly,
are you trying to "upload"? "hit upload" where, exactly? What,
exactly, would say what, exactly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should try installing by visiting routerlogin.net website on your browser (default username and password are: admin, password respectively). And then click on:
- ADVANCED > Administration.
- Click Firmware Update or Router Update and then choose the FW file location.
Detailed instructions below:
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank You very much. I will follow the instructions as provided and will get back to you and I promise to cut and past what is said. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank You Sir. I followed the instructions, downloaded the previous version of Firmware (V1.o.0.56.1.0.18) and then in the genie I enabled the parental control and it started working. Thank You so much for your guidance and help. I really appreciate it.
