× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
HeadPhones 0.7c85002
WhoCares_
Mentor
    • Description:
      HeadPhones is for music what SickBeard is for TV shows: An automated search tool that allows you to find and automatically send .nzbs to SABnzbd.
    • Requirements: RAIDiator 4.2.16+ (may work with earlier versions but that's untested)
      For this add-on to work,the Python add-on has to be installed on your ReadyNAS.
    • Platform: Intel
    • Changes in this release:
      - Initial release
  • Details/Installation:
      • After installation of the add-on, HeadPhones' web interface can be accessed by typing http://<ip of your NAS>:8181/ in your browser's address field.As an alternative you can use the quick link from the add-on's section in the "Services" -> "Installed Add-ons" tab within Frontview. You will be presented with a login screen.
      • The default username is admin with a default password of netgear1.
    • After logging in with these credentials please configure HeadPhones to your needs - don't forget to change your password 😉
Message 1 of 3
WhoCares_
Mentor
Re: HeadPhones 0.1
Updated to HeadPhones 0.1.1 v0.1.8
- latest version from GitHub
If you already upgraded your installed version through the HeadPhones web interface there's no need to install this one.
Message 2 of 3
WhoCares_
Mentor
Re: HeadPhones 0.7c85002
Updated to HeadPhones 0.7c85002 v0.2.4
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3236 views
  • 0 kudos
  • 1 in conversation
Announcements
