- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300v2 and Facebook Wi-Fi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function.
The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every time I click "configure" in Facebook Wi-Fi page, browser takes me to erroneous page: https://www.facebook.com/wifiauth/config?gw_id=
After that Netgear Genie becomes irresponsive and only reboot helps to get again into Administration panel.
Perhaps somebody can hlep me?
I suspect that Facebook has changed the page url for this kind of configuration.
What is the right Facebook page link to configure such things?
Perhaps it may help. Router is phisically located in Latvia.Serial Number: 44015177012F1
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300v2 and Facebook Wi-Fi
Hi folks,
I have exactly the same issue, facebook wifi option totally stuns the netgear r6300v2 router. After clicking on configure button a new tab is opened - https://www.facebook.com/wifiauth/config?gw_id= - and the router GUI becomes unresponsive (only if I unplug and plug back the AC adapter I can enter the GUI again). I have the latest firmware (V1.04.6_10.0.76) and latest Netgear Genie (V2.4.34) which btw is totally useless for facebook wifi feature simply because there is no such option anywhere in Netgear Genie app (only basic router settings there). I've also noticed that if using Chrome or any chromium browser (Comodo, Torch etc ...) for GUI, the facebook wifi button is not visible because its hidden behind the help bar in lower part of the window (I actually made it by using the tab button on keyboard to select that option and hit enter - of course the poor router got stunned again even from chrome after hitting the configure button). GUI works fine from Firefox and IE but still the only thing that configure button for facebook wifi can do is to stun the GUI (router itself still works, internet connection is OK but the GUI becomes unresponsive, even with closing the page and trying from other browsers I can't login to router anymore unless I unplug the AC and plug back in). I've searched and searched for the solution but nada, and I'm really good in searching for solutions ...
I think its a bug in the firmware but I wont downgrade it cos I've already lost too much time with this toy router, hope that Netgear will fix this issue soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @pcebavaro,
1. Does the issue persist when using other device/s (another computer, mobile device)?
2. Have you tried doing a factory reset?
3. Have you tried re-flashing the latest firmware?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @pcebavaro,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I also having similar issue here. When i click "Configure" under "Adcanced Setup --> Facebook WIfi", it will link to https://www.facebook.com/wifiauth/config?gw_id= but the page is not available (with message below). Tried on IE and Google Chrome. Can you please help?
Firmware version: V1.0.4.6_10.0.76
Sorry, this page isn't available The link you followed may be broken, or the page may have been removed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
I am also directed to a "page not found" error on the following link: https://www.facebook.com/wifiauth/config?gw_id=
My firmware is
V1.0.4.6_10.0.76
Any help appreciated.
regards!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i also have same problem after clicking configure it says page does not exist please help !!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same problem, has anyone gotten a solution to this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is the problem that molesting me for last 10 days. "Broken link, page does not exist..."
Please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
My firmware is
V1.0.4.6_10.0.76
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
I have recived your acknowledgement,
but there is resolution steps from your side.. Please consider high priority on this case..
BR,
Adusonu
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
I have same issue as EVERYBODY ELSE!!!
I get same result: www.facebook.com/wifiauth/config?gw_id=
You seem to be sending some emails to each persons email, and they never come back to complain
Can you please help me with this issue
Thanks
Samir Al-Busaidy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
So far no replay from your side...
Let me know, is there any option to make the facebook WiFi in netgear 6300v2 router ?
I have tried with multiple firware .. there is no luck....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hola acabo de comprar para usarlo en wifi de facebook y me encuentro con este mismo problema, que veo no tiene solucion...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
And the UI is frozen.
My firmware is
V1.0.4.6_10.0.76
regards!
P.S.: Maybe you can publish the solution (if any) given it seems many users are experiencing the same issue
