Orbi WiFi 7 RBE973
Reply
FVS336v3 NBN connection
stevenshaw
Tutor
Does anyone know if the FVS336v3 can be connected to the Austrailan NBN connecting via the service provider TPG. No matter what I have done to date it will not connect and I have tried most?
Also does the new model BR500 connect to the NBN?
Model: FVS336Gv3|ProSafe dual WAN gigabit firewall with SSL and IPSec VPN
Message 1 of 5
JohnC_V
NETGEAR Moderator
Re: FVS336v3 NBN connection
Hi stevenshaw,
Welcome to our community! 🙂
We don't really have any compatibility issues regarding NBN. May I know if the FVS336v3 is going to be connected to a router or modem? You may need to check the IP address of the router as it will cause an IP conflict connecting from NBN.
JohnCarloV
NETGEAR Community Team
Message 2 of 5
stevenshaw
Tutor
The main issue is in this link https://community.tpg.com.au/t5/Broadband-Internet/Alternate-router-to-use-on-HFC/td-p/863 on the first page down in the thread the VLAN settings linked to the 802.1Q tag.
TPG set up is in the following link.
http://tpg.com.au/support/setup-nbn-hfc/modem-wiring-support.html
https://community.netgear.com/t5/Hardware-VPN-Firewalls-and/FVS336-V2-NBN/m-p/1701247 this link asked the same question but for the FVS336v2 - no answer either.
Message 3 of 5
stevenshaw
Tutor
Also I am not interested in the VOIP function.
Message 4 of 5
JohnC_V
NETGEAR Moderator
@stevenshaw,
I see. My apologies. I'm not familiar with that. As per checking, you may just need to assign VLAN ID 2 to the WAN port. That's what I read on the thread that you shared and we cannot do it on the FVS336Gv3.
JohnCarloV
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2365 views
  • 0 kudos
  • 2 in conversation
Announcements
