- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PR60X
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the PR60X just a basic firewall? Is there a way to do advanced type of configurations like blocking sites, spam detection, malicious URLs, DOS prevention, etc...?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
According to the readily available PR60X product documentation, the Product Data Sheet, and the User Manuals its a pure dual WAN firewall with some VPN capabilities - however not a fully fledged Unified Threat Management (UTM) or the like.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PR60X
Thank you so much. Seems like a fairly expensive solution for not having any threat management.
Yes, I didn't see anything in the documentation, but wanted to make sure there was no add on somewhere.
Do you have any recommendations for something that has threat management?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PR60X
Expensive? If you compare to single or dual WAN Gigabit appliances probably.
It's powerful and capable firewall hardware...
High performance hardware 10G/Multi-Gigabit throughput and 1x2.5G WAN, 1x10G/Multi-Gigabit
WAN/LAN configurable port, 3x2.5G LAN and 1x10G SFP+ LAN.
WAN-to-LAN Throughput When using WAN2 port - 10Gbps max WAN with 17.5Gbps max LAN
When using WAN1 port only - 2.5Gbps max WAN with 27.5Gbps max LAN
...even if Netgear still does not publish IPsec VPN throughput numbers, unless I have missed something.
For UTM systems, look out for Check Point, Fortinet, ZyXEL, Sophos, just my personal preferences of choice for example.
