Orbi WiFi 7 RBE973
Reply
Site to Site SRX5308 y Zyxel USG50
LuisMaria
Hi.
I have done the Site to Site configuration of a NETGEAR with a ZYXEL and do not connect.
I have reviewed the configuration and I have updated the firewall and in principle everything is fine, but they do not connect.
Has anyone made that configuration?
If NETGEAR with ZYXEL is not compatible, what other brand can I test ?, thank you.
Spoiler
Model: SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Message 1 of 9
DaneA
NETGEAR Employee Retired
Re: Site to Site SRX5308 y Zyxel USG50
Hi LuisMaria,
Welcome to the community! 🙂
I'm not sure if you have already came across with the article below.  However, kindly use the article below as reference guide on how to configure box-to-box IPSec VPN:
Configuring a Box to Box VPN on ProSAFE/ProSECURE routers using the VPN Wizard
Make sure that the WAN IP address registered on the SRX5308 and Zyxel USG50 are Public IP addresses.  Also, be reminded that the LAN subnet on the SRX5308 should different on the LAN subnet of the Zyxel USG50.  For example, if the LAN subnet on the SRX5308 is 192.168.1.x, then the LAN subnet of the  Zyxel USG50 should be different like 10.10.10.x or 192.168.9.x.
DaneA
NETGEAR Community Team
Message 2 of 9
DaneA
@LuisMaria,
I just want to follow-up on this.  We’d greatly appreciate hearing feedback.
DaneA
Message 3 of 9
LuisMaria
I have done everything from the documents and configurations that NETGEAR has supplied to me and nothing at all (what I do not know if the connection problem is NETGEAR or ZYXEL
If you can guide me in things that I can try, I will do it agusto
Message 4 of 9
DaneA
@LuisMaria,
Kindly post screenshots of the VPN settings you have configured on the SRX5308 as well as the Zyxel USG50 so that other community members who are familiar with Zyxel could chime in and share their knowledge.
DaneA
Message 5 of 9
DaneA
@LuisMaria,
DaneA
Message 6 of 9
LuisMaria
Hello good afternoon.
I upload the NETGEAR and ZYXEL settings.
The Site to Site configuration between two ZYXEL works, so I understand that it is setup in the NETGEAR what is failing.
Message 7 of 9
DaneA
@LuisMaria,
You mentioned: "I upload the NETGEAR and ZYXEL settings..."  -- I have already verified and approved all the images here in community as of now but it seems you have not posted any images (or screenshots) of the VPN settings you have configured on your SRX5308 and Zyxel USG50.
Kindly post images (or screenshots) of the VPN settings you have configured on your SRX5308 and Zyxel USG50 so that other community members who are familiar with Zyxel could chime in and share their knowledge about it.
Check the image below on how to insert images or screenshots when you reply:
DaneA
Message 8 of 9
LuisMaria
Let's see now, I'll hang it again
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5050 views
  • 0 kudos
  • 2 in conversation
Announcements
