Orbi WiFi 7 RBE973
Reply
5.1: Switch - Uplink Port
schumaku
Guru
The index of the icons and items used on the switch device view does list an "Uplink Port".
How can we define port(s) resp. LAG(s) connected as Uplink?
Message 1 of 3
MrJoshW
NETGEAR Expert
Re: 5.1: Switch - Uplink Port
Hello,
I was able to create a lag on the uplink port but you're right it does not seem to list that the port is part of a lag. I've reported this one to engineering.
Message 2 of 3
schumaku
Guru
@MrJoshW ... with the Uplink being on a LAG (where these virtual LAG ports are poorly visible - let's discuss this in a dedicated thread) there is no indication (or it's not detected).
There will be even more fun: Starting from later this year we will massively extend the venue site and configure an RSTP controlled redundancy connections. This can make the uplink change dynamically.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1893 views
  • 0 kudos
  • 2 in conversation
Announcements
