Torred's avatar
Torred
Gs105ev2 link light on, no network cables connected
Both of my GS105EV2 switches are doing this, all of a sudden today. I disconnect all cables. I plug in the power cord. The port 3 link light illuminates green. No matter what I connect, to any port, nothing changes. Is this an indicator of some trouble code or something?
I've tried factory reset. Letting it sit for 30 mins and trying again. Switching power cables, network cables, and power outlets. No changes.
Any thoughts?
  • So after talking with support on the phone, it looks like the switches are dead.  It could have been a power surge through the network cables, which would explain why I lost all 3 of my switches at the same time.
    My computers were fine, but I think they use a Z-Diode on the NIC to prevent frying it from power fluctuations, where I don't believe the netgear switches do.
    To answer your questions though, there was no network traffic flowing and I was using the latest firmware.
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Torred,
    Welcome to the community!
    Blinking LEDs is an indication that there is activity on the port. If you are saying that the port LED blinks without anything plugged into it then that is weird. I have some questions to help us isolate the issue, I have listed them below:
    1. Does the switch(es) stopped passing traffic?
    2. Are they still detected by the ProSafe Plus Utility?
    3. What firmware version are you running on the switches?
    Looking forward to your response.
    Thanks,
  • JohnRo's avatar
    JohnRo
    Hello Torred,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
    • Torred's avatar
      Torred
      • JohnRo's avatar
        JohnRo
        Hi Torred,
        Sorry to hear that, I looked up your record and found that the switches were replaced. Hopefully the new units will not have any issue.
        Thanks,
ProSupport for Business
